I need any advise on installing pre pump filter and moving the pump closer to the fuel tank. I bought Baldwin filter set up. Any help would be greatly appreciated. Thanks
Mike
I was told that by moving the pump closer to the tank, it would cause less air in the fuel lines. Since the pump would be closer to the fuel in the tank, it would create less air in the fuel lines. Maybe not correct, but it makes sense to me. Thanks for the reply
yea, it makes sense. My buddy made me believe that moving the pump would create less air. Thanks for the info. I think I am going to go your route. Have you heard anything about removing the check valve on the pump, not sure if it is on the inlet or outlet side, but I was told that it can be removed so that you eliminate another restriction on the fuel line. Thanks for your help.
Mike
Wasn't there a theory about diesel have naturally entrained air in it that released under vacuum.........even in the absence of a leaking quick disconnect fitting........or I could be getting old timers.
Maybe this is the reasoning behind moving the pump.
Tbar
