Power windows auto down does not work
8kgold69
Sanford, FL
Hello Gentlemen
I have a 2014 F-350 Lariat Super Duty. It has the one touch auto up and down button option. It is the left front door, drivers door, it will come up automatically, but will not go down automatically. I've replaced the complete motor and regulator assembly, I have tried the programing procedure and just can not get it to to go down automatically. The passenger front window, right front, works great. Any suggestion? Appreciate any advice and/or directions.
Thank you
bigtruk
Reno
Hey stupid question here but did you replace the switch? Not sure if the momentary aspect is in the switch or the motor? I read that you replaced the motor and even did some programming with FORScan I presume? And really... that programming shouldn't have changed. You may as well replace the switch if you haven't. Keep after it dude, you'll figure it out.
william maynard
co
Hello Gentlemen
Thank you
i read somewhere that sometimes the programming needs to be redone after a repair. the post said hold the switch in the down position for at least 10 seconds to reset auto down, same goes for up... hope it helps
