power steering
jccapri
garland,tx
Last night I was back in the trailer in the backyard turning hard heard a moan and a pop now I only have power steering when I'm moving or wrapping up the motor wondering if
I may have a valve I may have blown
Any PS fluid on the ground ? Any brakeing issues ? If not.. sounds like you may have blown a PS pump seal. These pumps are not that pricey to R&R.
jccapri
garland,tx
No fluid leaks and if you bring the RPM up you have powers
It gets purdy NASA like, but when these pumps go.. they are gone... as far as being On Spec for SAFETY SAKE. It is basically just a Hydrolic Pump. You can rev'm up and they will build enough pressure to [KINDA] work... but the tolerances are gone... at low RPMs.. Thats what you are seeing.
For the cost.. they're not re-buildable. best bet is to replace it.
You're right I called and checked into Rileys about 51 dollars
;tu Good Call. Best 50 bucks.. for the Safety of you & yours.. you could spend.
If you've never changed one out.. get back to us.. all kinds of help here on the wayz to git'r dun. (in yer driveway)
No I've never changed a 7.3 is it much different from a regular truck
No, not much different than any other. Use the SDD search feature.. plenty of info there. And there's a couple of current members that have posted lots of DIY info too ?
Maybe some of them will jump in when yer ready too ??
