POWER STEERING / POWER BREAK LOSS help me
bartman
Dallas, TX
I don't believe that the resevoir is pressurised. It weird that the problem is fixed, but I would keep a sharp eye out for a recurrance.
bartman
Dallas, TX
Sounds like you may experience this problem again. I have never seen spray fluid and then be fine. Just be careful when you drive for you may lose brakes and steering assist again.
pump cavitation...
if you have a vacuum brake bleeder, you can use the single master cylinder cap and put it under vacuum for about ten minutes... them top off the fluid and drive.
PUT A NEW BELT ON IT BEFORE IT BREAKS!
Brad1103
