They are hard to pull even after I lubed and removed the zip-ties on them. They are not even trying to rise, as a matter of fact they are locking when I hit unlock on the remote.
I found the Diagnostic Routine for the door locks on my service CD. Many Connectors and Circuits to test but they don't really tell you where the connectors are.
1. Locks Will Only Lock or Unlock
2. Possible Source(s):
§ Circuit.
§ Switches.
Action(s) to take:
§ GO to «Pinpoint Test C»
C15 LOCKS WILL ONLY LOCK OR ONLY UNLOCK
l Key OFF.
l Disconnect module Connector C3.
l Check continuity between Pin 4 Circuit 119 (PK/Y) (Pin 5 Circuit 120 [PK/LG] if doors will not unlock) of Connector C3 and ground while pressing the lock (unlock) position of one of the door lock switches.
l Is there continuity?
Yes
GO to «C16».
No
GO to «C17».
C16 CHECK OUTPUT FROM MODULE
l With all connectors in place, check voltage between Pin 2 Circuit 117 (PK/BK) and Pin 16 Circuit 117 (PK/BK) of Connector C3 (Pin 3 Circuit 163 [R/O], Pin 6 Circuit 118 [PK/O] and Pin 18 Circuit 118 [PK/O] for unlock) and ground while pressing the LOCK (UNLOCK) position of one of the door lock switches.
l Is voltage 10 volts or greater?
Yes
SERVICE open or short in Circuit 117 (PK/BK) (Circuit 118 [PK/O] or Circuit 163 [R/O] for unlock). REPEAT «Pinpoint Test A».
No
REPLACE remote entry module. REPEAT «Pinpoint Test A». (hope it ain't this one, module is $363.67 )
C17 CHECK DOOR SWITCH FUNCTION
l Check continuity between ground and Circuit 119 (PK/Y) for lock (Circuit 120 [PK/LG] for unlock) connection to door lock switch while pressing the LOCK (UNLOCK) position of door lock switch.
Yes
SERVICE door lock switch. GO to «C18».
No
SERVICE break in Circuit 119 (PK/Y) (Circuit 120 [PK/LG] for unlock). REPEAT «Pinpoint Test A»
