being a machinist for a living I was looking at an egr cooler and started thinking if you made a 3/8" thick plug for both ends of the exhaust ports press them into place then weld them what you would have is a sealed tank that would allow the coolant to enter the back side pressurize the tank then exit thru the port going into the intake.
then make a slug with an inverted radius on the end to plug the up pipe this slug would be the same dia and pressed into the up pipe then welded at the flange so no heat from the exhaust can get to the cooler any ideas I am just trying to get my truck running in time for camping season
