Got home from work Sunday night & had not even had the chance to take a load of my mind & the sewer backed up flooding part of the basement
1 of the kids was sick & while the drain was slowly going down ifin the terlet is flushed it backs up.
Called a 24 hour guy & he was here in around 45 min
Plumber guy ran out 105 feet of 3 inch snake pipe to the city connection and it took forever & he had to use a couple different cutters till he finally broke free the plug.
He said we have 3 inch pipe out to the city sewer & that while there were some roots in the pipe the end had slipped to an offset instead of straight on so it's not the full 3 inches.
Had to put on some kind of spring cutter instead of the H cutter to get through the end into the city pipe.
Had about 3 feet of roots on the end of the pipe when the snake was finally pulled free.
He recommended the sewer line be snaked every 6 months
He did not have a wax ring so thankfully Lowe's is not far and Monday I got a new wax right with a plastic funnel on it to seal things back up again & make that terlet usable. Also got a bottle of stuff that ya dump in the crapper & flush before it over flows the terlet with foam.
This stuff is reported to kill roots & clean out roots in your pipes.
Was told that this foamy stuff works just as good as having a plummer come over and clean the sewer pipe once a year, just use it twice a year & it will keep your pipes clean of any roots.
Figured it can't hurt
Now the toilet that is upstairs is flushing slower than normal is this due to cleaning out the pipes, or something else??
Is it normal to snake your pipes every 6 months, or is this just a scam
Any other maitanace the sewer system needs to help keep it running without clogging up with tree roots again???
