Opti-Lube Diesel Fuel additive - F250 Gallon Tank Long Bed = ___?
jwplunkett
Colfax NC
Good evening all
Per recent study Opti-Lube XPD ranked # 2 out of 19 Diesel fuel additives for lubrication improvement properties of the NEW ULSD Diesel fuel ( 15 PPM )
Ranked # 1 was 2% REG SoyPower Bio-Diesel
I was using Amsoil Diesel Concentrate but it was ranked at 9
Anyway I ordered 3 gallons of the Opti-Lube XPD to give it a try in a couple tank fulls of ULSD diesel in my area that is all that is being sold --- the older 500 PPM I cant locate ---- the Opti-Lube XPD is scheduled to be delivered Tomorrow .
So I looked in my Ford Owners manual for Fuel Tank Size so I may mix the proper ratio recommended by Opti-Lube XPD --- has a 256:1 ratio based on a 26 Gallon Tank per study --- 13 Oz per 26 Gallon tank ---- estimated cost = $ 4.35 Tank.
Finally :) for my question the Factory FORD Owners manual has Four Tank sizes listed ( Page 289 )
-I believe I have the Long Box tank that states 38 Gallons is this correct ?
-Does long box also cross reference to long Bed ?
I have a regular cab long bed Model Yr 2006 FX4 Auto Trans
Your assistance as always is most appreciated
John from Colfax NC
Maxtor
Redding
Good evening all
John from Colfax NC
Read this;
It says long wheelbase trucks have 38 gallon tanks.
Ford Super Duty - Wikipedia, the free encyclopedia
jwplunkett
Colfax NC
Opti-Lube Diesel Fuel additive - F250 Long Bed = 38 gallon tank
Many thanks for your forum web return
Exactly what I was looking for and MORE :)
-F250 Model Yr 2006 FX4 Reg Cab Long Box ( Bed ) 6.0 Diesel = 38 Gallon Fuel Tank
-Per my calculations Will require 19 Oz of Opti-Lube XPD
( Multi-Purpose + Anti-Gel, Cetane Improver, Demulsifier )
319 Micron Improvement
256:1 Ratio
For anyone interested + to do own independent research I have provided Opti-Lube XPD web link
Diesel Fuel Improver
Hope this helps a bit
Study was based on a 26 Gallon Tank ( 13Oz per Tank in study )
Study stated $ 4.35 Tank
I have printed out a hard copy and will insert same into owners manual
Great weekend to all
John from Colfax NC
pete37922
JERZY
ive used lucas...powerservices...and Amsoil diesel concentrate !!!
