Online fittings source?
CPUNeck
Reclamation Specialist
Ft. Campbell, KY
bluefxstc said:
someone said that the stock check valves were not really check valves
Bluefxstc
Blue,
Those so called check valves are in fact just restrictors. I forget who has some shots of them, but I still have mine and would be glad to disassemble them and take a pic or two ;) Instead of a "ball" replace that with a cone shapped piece with holes around the pointed part. This whole thing is spring loaded as a ball would be, but the holes alow "bleed". After I got my system in I'm fairly certain it has to do with the pulsing experianced in the fuel rail at the head. Removing these could cause some interesting ideling and I believe the only reason I don't have this problem is I have replaced the rigid fuel lines with flexiable lines and I can feel the lines expand and contract as the engine is ideling. Hope that helps :cowboy:
bluefxstc
Hog Flyer
Boise ID
CPUNeck said:
Blue,
Thanks CPU
That is what the individual at TDS had said also. He had originally pulled them out but had rough idle problems so he put them back in. I have a couple of check valves I just need to figure out how I want to plumb it now. It will be more work than originally planed but I guess that is half the fun... ...or so they say. :rolleyes:
Bluefxstc
Ricksofla
