Ok, Injector cups replaced/all well but now have smoke
Cherokee said:
Where the oil is coming out of is that threaded bolt looking thingy.
I dont really know if that is the correct name...
Any help?
If it is coming from the area under/behind the turbo, its probably the EBPV actuator, did you guys unhook this rod during your recent work? For whatever reason if the actuator rod isnt hooked to something it will leak.
Bulrid8
Don't Fear the Reaper
Live Oak, FL
I say someone needs a serious engine cleaning!! That would make finding leaks, alot easier!
Wood County Tx
no no thats a new mod. its an external oil leak preventer :roflmao :roflmao :roflmao , its worn off that greasy spot :D :D
I was told when I had a white smoke problem after doing my injectors that it was somewhat normal due to air in the fuel system and you just need to drive it around some to get the problem worked out.
On a side note I did have an IPR problem @ the same time.
As for the oil leak everyone else has already hit the likely cluprets.
Ricksofla
