02Oilburner
SDD Power Hungry
I ran my AE today and got some codes
I know what the codes are, I just need to know how to fix it
P1832 Transfer Case Diff. Lock up Solenoid Failure. Where is it so I can change it?
P1876 Transfer Case 2wd Solenoid Failure Where is it so I can change it?
Does this mean Im stuck in 4wd Hi. Hubs are unlocked but could this be the vibration noise at 1600 to 2000 rpms Ive been having for months?
When I first ran the AE this morning after warmed up and 10 miles I got the above codes and (p0605 Ive had this before),u1262 Com bus fault, P1316 IDM codes detected, P1273 Cylinder#3 High to Low side open
I saw this somewhere today P1273 High to Low Side Open - Cylinder 3 - This means there's an open in the wire between cylinder 3 injector (right bank) and the IDM.
SO I clear the codes and drive for about 20 miles and heres what I have now
Contribution Test=no codes
KOEO=p0605, p1273
KOER=no codes
Buzz test=p1273
I think this is my loping problem
What you guys think I need to do? Thanks for your help in advanced
KOEO=p0605, p1273
KOER=no codes
Buzz test=p1273
