Smoky
I think I have found where my oil leak is coming from. On the bottom side of the valve cover on each side is what appears to be a wiring harness that goes into the engine or valve cover at each cylinder. I am assuming there is an oring or grommet for each point that it is inserted. What is this called and what do I need to replace to stop the leaks?
View attachment 12837View attachment 12838
