Help Needed Oil filter cap split open
Redrig
Rig Monkey...
Vancouver Island, BC, Canada
Hey gang, I have an issue with my 05 6.0l, the other day I was driving over to the folks place, about a 2 min drive, I made it a block away from the house, when I heard a nasty sound...kinda sounded like the turbo grenaded, the truck died, pulled over, jumped out to see what the prob was...the truck puke out about 12L of motor oil on to the ground, popped the hood and found that my oil filter cap split open and purged the oil out. picked up a new cap and filter, added some oil, it still makes that noise, even worse when its in gear and I just barely touch the throttle...
...any thoughts? :dunno
fordoor
SDD Member
N. Calif.
Geez Man!! What a catastrophy. I haven't heard this one before. Did a little piece of your Turbo "grenade" and break open the oil filter cap? External or Internal seems to be the question. Everything look o.k inside the filter housing? Broken spring/bypass in the stand? I'm anxious to hear about this one.
bismic1
Was the oil filter an OEM or aftermarket filter/cap combo? To me, it sounds like it could be something in the HPOP.
Redrig
Rig Monkey...
no the turbo is still good, the oil filter is the one piece design, cap and filter together, I had to go back to work (in camp) shortly after it happened, so I havent had a chance to really take a good look at things, I'll post more when I know more....I sure hope its not the high pressure pump, that will be a pretty big bill...
ckamp52
ckamp52
italy,tx and stephenville
i have cracked a few filter caps as well went to a billet one to solve that problem..have you checkd all the clamps on the boots and intake? mine made a weird sound like that one time soon after i installed my boost gauge and i had forgotten to tighen the clamp back onthe intake elbow or maybe it was just a turbo fart?? keep us posted
fordoor
SDD Member
N. Calif.
A few? I don't understand this problem. Are you guys over tightening and torqueing the top of the filter cap top to the breaking point? I have 7 years and 22 oil filter changes on mine and the cap looks like new. Did the caps get made differently/cheaper after 03'?
georgetown texas
If you use the square hole they have a tendency to crack which is why i use that big socket that fits the bottom fuel filter.
That is the reason that I went with the 36mm socket, as well. You look at the insides of the square drive and you will see stress marks where the drive and the socket meet.
fordoor
SDD Member
N. Calif.
I get it now. I've always used the socket so never had the problem. Good for all to know. Thanks Dave.
;tu fordoor
Not Bashing anyone here guyz but.... 90% of the time.. TIGHTER is Not Better.
(don't ask me how I've learned that thru the years. The list would be to long;):lmao)
TacoCat
