but consider there is an operating range for fuel pressure, and knowing that it runs means that there is enough fuel being fed to the motor.
i do not recall what the range is.
makes sense that the pressure drops at load.
are we still chasing excessive oil consumption?
you got a manual JR?
dp
Well it looks like I've got some work to do!
Yea, I would understand it dropping under load, but a 20 psi drop???
No longer chasing the oil consumption...that seems to have gone away with the new injectors. What I'm still chasing is the hiccup and unburt fuel/oily residue on the back bumper.
I've got a theory here...tell me if I'm crazy...
The vibration that I've been feeling at or above 2500 rpm's...could be the engine running out fuel and shaking?
A bit redundent but........Follow me here ?
1. The OEM fuel pump is about 100 psi capable. The FPR, stock, regulates the fuel pressure at about 45-60 psi.
On demand.. throttle response is OEM acceptable.
2. Raise the fuel pressure to 70 psi.
On demand.. throttle response is noticeably Better.
Givens.
In Jourdan's case.. In the FPR, the spring loaded piston (valve) that controls the fuel pressure.. the O ring seal is defective, allowing the fuel pressure to bleed off.. and return to the fuel tank. AND.. A filter in the supply system is plugged.. reducing the fuel pump's psi capability.
Results ? The Base Fuel pressure is even below.. OEM specs.
The engine will start, the truck is drivable, but On throttle Demands.. the response is irregular and has a "Hiccup".
The engine isn't running Out of fuel.. It's Starving, for fuel Quantity, and it's needed.. at least OEM, injector Pressures*.
(*not mentioned... what effect the Low fuel pressure is haveing on the Injector pressures ( bogus spray patterns= wet tailpipe ?)..)
Rebuild the FPR and R&R the filter(s).. I'd Betcha the issues Go Away.
Make any Sence, JR & DP ?
