Fuel Pressure
Well, I ended up getting around to attempting to get an accurate reading of my fuel pressure...
Even with the 1/8" tubing (and a shorter length at that)...I still got 38 psi of pressure. It ended up settling at about 40. I went and drove it and had the gauge sitting on the windshield. All was fine and it remained stable. When I nailed it...the pressure dropped nearly 20 psi down to about 20 psi from 40 psi.
After that, I went ahead and took apart the FPR to have a look. First, it looked ok, then after closer inspection I saw that there is some sort of black o-ring type fitting that goes around the brass sleeve that then sits inside of that little ring, that then sits inside the fuel bowl housing. (Mouthfull, but make sense?) That little o-ring was ripped/degraded. Everything else looked fine (main o-ring, spring etc)
Could this be letting pressure by and not regulating things properly?
One other thing I checked was the in line fuel filter just before the pump. It's pretty dirty and full of crap, and needs to be replaced, but i doubt thats causing my fuel pressure to be 30 psi low...
I uploaded pics with this...lets hope they show...
