Oil and Fuel pressures
Digital Oxygen
Got Boost?
Rockies
Where are you guys tapping Oil and Fuel pressure senders for aftermarket gauges?
Thanks a bunch
CSIPSD
Bend, OR
What truck? SD or OBS? On a SD there is a port next to the oil filter, and another one on top of the HPOP. For fuel there is a port on the drivers side rear of the filter ass.
Also added the Tranny port and the water temp port... The Fuel pressure is a bad shot but it gets you in the right place...:sorry
Digital Oxygen
Got Boost?
Rockies
Sorry...
03 6.0 liter. I have the water tapped into the engine block, and the tranny tapped in the location you have.
nascar_fan28
IL
i bought an oilgaurd oil filter cap, then just hooked oil sender up to it.. works great doesnt look bad
Digital Oxygen
Got Boost?
Rockies
Well hell. Oilguard won't sell me just the cap. Do you guys have any other suggestions for where I could go for one?
Thanks a bunch.
FTG-05
North Alabama
Thanks a bunch.
Why not? I bought the Oilguard oil filter cap and the oil filler cap for my Amsoil BK-13 bypass filter system.
Did you call or try over the internet?
nascar_fan28
IL
i think i just called them.. they just sold me flilter cap.. lil expensive think 90 bucks
Bolt
Plainview, Texas
You need the fittings like this picture, that way you can tap into the factory oil pressure sending location.
That starts with a Male #4 to 1/4 SAE female swivel.
Then a 1/4 nipple and T.
On the side of T put a 1/4 NPT male by #4 Female O ring seat the thread your factory sender into.
Then screw your aftermarket oil pressure sender into the top of the T, and you are all set.
gotogelsuper8461
