Noobie From Oklahoma
Nharmswhey
Moore, Oklahoma
Howdy yall. Just sold my 04 F150 and am looking at getting an 06 250 with the 6.0l of course. Looking for advice on what to look for when i got drive it and about what its worth. Then of course after i get it. Modifyin it.
atk
Moderator
simcoe, ontario, canada
Welcome to SDD....
I would recommend on getting an OASIS report from a Ford dealer. it will tell you what work has been done on the truck at a Ford dealership....also check the trans fluid, just make sure it doesn`t have a burn`t smell and a brown colour to it....also check around the Degas bottle(coolant bottle) area for any white crud(coolant from being overheated), which could indicate an overheating problem and or headgasket issue....if it is a 4x4, check to make the hubs work properly and the 4 wheel drive engages like it should....for a 06, up here they going for anywhere between 24000-35000CDN, depending on mileage, trim level and cab configuration....hope this helps
also, don`t worry, we can help spend your your money for the mods....:D
scottu5
