Question No Start.
35kl199
US
Hi there all. No start after replacing dummy plug and standpipe on driver's side. I used the starter wire to build oil pressure but no luck. Koeo dash oil gauge is at the bottom, but while cranking it goes up and goes down after 3-4 sec later when i let the ignition go. Ficm sync is 0 koeo. The truck had hot no start problems before i started to replace the dummy plug and standpipe on ds. But it used to start when cold with a little hard start problem within 3 sec.Any suggestions?
2005 F250 6.0 137000 miles
Thanks.
Sent from my SM-N950U using Tapatalk
Ricksofla
