parttime
this morning went out and fired the truck up and it started right up like it always does while i let the dogs out,after about a couple of minutes it but then all of a sudden it start acting like it was running out of fuel and went to skipping and i went to get in th truck to shut it off and i hit the pedal to try and see if i could clear it up and it went to about 1600 rpms and that was it and it then died.now it will not start.i replaced the fuel filter this morning, and then it still wouldnt start so i checked for any codes with the edge evolution and i got the PO344 which is the CPS,replaced it and still no start.it is smoking white while it is turning over.i cleared the code after i replaced it and it has now set the same code again after it turned over several times after replacing the CPS.i am going to be replacing it again just to make sure it isnt a bad sensor.I went to a buddy's shop and borrowed his otc scanner and hooked it up and it says that all systems pass.it ran its series of test and i heard all 8 injectors and they sounded the same.only test it couldnt run was the gp because it will not start and it has to be running for that test.i am going to be checking the fuel pressure this afternoon when my neighbor gets home, he is a mechanic at the local ford dealership and was the diesel tech at the local cherorlet dealership until they got the letter that no dealership wanted and it seems to have him puzzled over the phone.he is going to be bringing home with him another CPS,fuel pump,ford scanner and the fuel pressure guage to check it with.any thoughts or has anybody else ran into this problem before and any help wold be great.
here is something else
i just went outside to try and hold open the sraider valve while my son spun it over and i got air so i pulled the filter out there was some fuel in it not much but some and let him spin it over while i looked in the bowl to see if it was filling up the bowl and while he spun it over it filled up the bowl and it was also trying to hit with the filter off and with the filter on it wouldnt hit a lick just spins over.this has me stumped and several others also.any help would be appricated
this is on a 1996 F250 4x4 7.3
