Agreed
I guess you would not know if I was working on my 2001 Craftsman lawnmower with a chevy 454 and a Hamilton Standard propeller on it or my 2005 F-250 crew cab with the 6.0 Powerstroke,Automatic Trans all stock at this point.I picked it up in houston,TX with 179,000 miles on it and it now has 181,000.The only thing I have done to it is replace the fuel and oil filters once at 175,000.It was running just fine the knight before and when I went to warm it up in the morning it was a little hard to start which is unusual,I then went to comb my teeth and brush my hair about 5 minutes and walked out to find it not running and tried 3 or 4 times to start it.It did fire a couple of cylinders but not enough to keep it going,one of the times I did step on the throtlle and white smoke came out of the exhaust.From the best of my knowledge that is what took place.The first thing I am going to do is replace the fuel filters then go from there it needs to be done anyway and could just be problem,I would appreciate any suggestions though,Thank You
