cb5300
Hi all...I'm new to this forum and hopefully you guys can help me out. I have a '06 F350 dually (Lar) 4.30 gears with tow boss and tow command. Problem I have is that the truck doesn't make the hp ford saids that it's suppose to make. I replaced a '03 with this truck and have been disappointed with the power ever since. Truck has been to dealer four times trying to fix the problem, but it doesn't throw any codes. I had to actually take it and dyno the truck (at my expense) to prove that something was wrong. I dyno 222 RWHP with only 348 RWTQ. This doesn't work very well when towing my 44 ft enclose car trailer. The problem I see is that the truck is running over 18 to 1 A/F ratio (way to lean), and the dealer has been very understanding, but Ford says that it's my problem and they can't/won't do anything about it since there are no codes. Dealer and I both say that all ford needs to do is change the fuel tables and reflash the PCM. However ford factory tech claims that they don't know what an air/fuel ratio is.... I guess what I need to know is, has anyone else had a problem with their 6.0 not making the power that it should. Heard a rumor that ford was having problems with tranny holding up so they dialed down the 6.0 to try and ride things out until the new engine/tranny comes out.
