arrowstrap
BioMechanic
This is EXACTY what my truck did... to the T! same issues.
It was in fact the UVC wire harness. had to replace burnt harness, melted gasket and all plugs just to be sure they were not creating resistance heat in the harness UNDERSIZED wires. to be sure of the side i took a thermal reading of the engine while it was malfunctioning... seemed to be running off half the engine... and it was. the cooler side was the burnt side. aside from some bolts that are near impossable to remove it was a quick fix.
I replaced the plugs and harness on the other side a few weeks later and it when out as well.
