Question No DING when key is turned on.
predatorproblems
Central Texas
Ok, so I am having a problem. When I turn my key on my truck USE TO make several DING, DING, DING tones as your waiting for the glow plugs to warm up. A couple months ago it just stopped doing the DINGS. Everything seems to be working fine outside the noise being gone. I’ve checked the fuses under the hood and dash and all are good. I DIDN’T check the big bus fuses (I guess that’s what they’re called). Not sure how to do that. It’s one of those things that is driving me nuts cause I can’t figure out what happened. Anyway, any assistance is greatly appreciated.
MarkS
79jasper
El Paso, TX
Could just be the dinger. Lol Its under the dash, but I'm not sure where on your year.
snicklas
Super Moderator
Staff member
Greenfield, Indiana
That ding should be the seatbelt dinger. It has nothing to do with the glow plugs. If you have your seatbelt fastened before you turn the key on, it won’t ding.
Does the seatbelt light on the dash come on if you don’t have your seatbelt fastened when you turn the key on?
predatorproblems
Central Texas
When seatbelt isn’t buckled it’s silent as well as when it’s buckled.
Seriously.. If it Ain't Ding'n and everything is working.. Don't Ding with it ? Or worry about it ?
I had a GMC Van.. 2 weeks from New.. the Dinger Squealed.. and never Dinged again. I was Okay with that for +100K miles ?
hawkdriver
Lake Martin Alabama
Mine dings with the key out of the ignition and if the steering wheel isn't tilted all the way up. I'll take your problem instead of mine lol.
Tracy Mangus
Colorado
there is a sensor on the ignition switch, that senses the key inserted, may be that, I have it malfunction on my older truck and it ding all the time with the key in even after start, I had to disconnect it to shut it up. if it is disconnected, it does not ding, may be a bad ignition switch
