Help Needed New problem, reverse bog down
RogerR
Colorado Springs, CO
Here is the latest in my Ford problems, when the truck is warmed up, and you go from drive to reverse, it bogs down and usually dies, always starts right up and will then go in reverse with no problem. Any ideas?
check your transmission fluid.
if there's not enough fluid to engage the clutch pack, it will hang with two gears applied
RogerR
Someone else suggested that so I changed the fluid and filter and it still does the same thing. I will keep looking for answers. Thanks. Roger
wpfd571
White Pigeon Mi.
With our plow trucks that's a sign of a weak pump and most likely on its way out, i would get to a tranny shop a.s.a.p. before its to late.
