New member LEVEL and WHEEL question
jdhart73
KS
Hi guys, great forum here! I will use the search function when I get a bit more time but thought I would throw this out there.
Just bought a 2008 F250 6.4L FX4 and will be leveling (2.5 in front and 1 block in rear) and wanted to know what offset I should be looking at for wheels? I am wanting to run 20" wheels with a 35" tire (probably terra grappler). What offset? I want them to be wider obviously but not obnoxiously outside the wheel well throwing rocks on my black paint. Also, is a 9 or 10 inch wide wheel preferred?
Thanks!
Jake
strokepower
Stroke=Power
Cook Station, Mo
9 is plenty wide with the right tire to give you the "wide look" you want but ten is fine too.. its all about prefference.... im not sure if you can run a 20'' wheel with 35s and make it fit with just the 2.5'' leveling kit... i have the leveling kit on my 05 with 35s on the factory 18'' wheel and it has plenty of room but im not sure about a 20'' wheel... should be alright but i don't know for sure...
welcome to sdd.com
gregmc720
GrEgGy BoY
Pompano Beach, Fl
2.5" front with 1" blk in rear. no rubbing with my 35x12.50r20. Hope this helps.
Thanks!
Jake
trickyricky23r
