Well that's kinda another thought, crack the bolts, blow the gasket, tighten back to spec, and drop it off at Ford and have warranty pay for it. I got 10,000 miles left before its over so I would like not to pay for the trouble
the oem head bolts are stretch bolts. iirc, 12pt external drive. big flanged head bolt. they only toque to spec ONCE. they
the arp head studs are studs, that get run into the block. they are high grade, hardened, alloy steel that are heat treated and then the threads get ground
they are different fasteners
I am sure that the manufacture would see that the bolts had been removed and the studs installed, and then say something like 'voided warranty'. Be careful trying to get that kind of stuff past the manufacture.
I am agreeing. The other poster was trying to change out the bolts with re-enforced ones and take it back to the dealer and have them replace the head gaskets (under warranty) after stud replacement.Well thats kinda another thought, crack the bolts, blow the gasket, tighten back to spec, and drop it off at Ford and have warrantey pay for it. I got 10,000 miles left before its over so I would like not to pay for the trouble
