New clutch
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
I picked up my truck today after getting the South Bend installed and boy is the pedal easy to push now. How serious is the breakin period for the clutch? I plan on hauling two trucks on my trailer (over20klbs) this weekend? The only thing that bothers me is that I can hear a little tranny noise in nuetral now that I didn't notice before???? The dealership also fixed my oil leak that I thought was my rear main seal but ended up being the pan gasket. I removed the crankcase evac system that I had plumbed into the exhaust untill I figure out if that was the cause of the oil leak.
mech2161
Morgantown WV
You can remove the clutch assist spring under the dash to give you a little more pedal feel. A couple days should be enough break in time.
BigRamrod
