new addict needs cheap new tricks
kelbigd
Well cheap =
Tymar DYI intake 30$ theere is your cold air intake, Zoodad as mentioned above.
30$ at a exhaust shop to straight pipe the current exchaust.
10K mod as mentioned above.
Remove the AIH = free
CCV for 10$ but thats not for performace, but will keep the IC boots from popping off.
What is CCV and AIH??? I am new to the Diesel world. Thanks
firemediceric
Vero Beach, FL
Tymar Question
I think I want to do the Tymar air filter mod. When I looked at the stock box on my '99 I see a sensor inside. What do I do with this factory sensor (air temp. sensor?) that is wired into the stock filter box? What about the stock filter restriction guage? Does this Tymar get oiled and re-used or just replaced? Does it need a support bracket and if so what should be used?
Any drawbacks to doing this? How noticable is the improvement?
Thank you.
firemediceric
Vero Beach, FL
Is it needed?
i just read on the General Discussion section that the stock air filter provides more than enough flow fo the truck. Shhould I even bother with replacing my stock air filter system that currently has the K&N drop in filter?:dunno
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
The factory air filter box has had a lot of issues with bad sealing. The tabs on the end of the top are prone to breaking off, especially if one isn't paying enough attention or in a hurry (i.e. oil change places). A K&N filter won't fix those short comings because it uses the same factory box.
For those on a budget, a home-grown Tymar or open-air style element is a decent option. If you don't do a lot of summer time, heavy towing, it is a good way to go. It'll draw in air from under the hood, which can be an issue while towing. It was for me, which is why I changed to a Ford AIS and a Zoo-dad mod. The AIS/Zoo-dad takes in cooler, fresh air from the grille area which tends to allow everything to run at cooler temps.
Brad1103
