Nice ride...see
this post for sponsor links that sell the stuff
you want & the stuff you dont know you need
coolant filter 1st , then guages, then exhaust.
when you buy the coolant filter, get extra filters...the 1st one or two
will plug up <from all the sand and casting left behind by the factory>
i plugged my 1st filter in less than 1000 miles.
filtering the coolant will make your degauss bottle CLEAR (i couldtn
see the fill level in mine there was so much crud floating around) and
it will extend the life of your water pump as well as prevent clogging
of the radiator and other passages.
and oh yeah add
FUMOTOVALVE to the early list of things
to do...it makes changing 13quarts of oil EASY and almost CLEAN !
start shopping around for fuel, trans & Oil filters....youll be SHOCKED
at how much the dealer will want for 'em...and even more amazed
at how cheap you can buy 'em for on the net.
