Needs assistance, runs fine but wont move in gear
CLBurell
Knoxville/TN/USA
Truck starts and runs perfectly. When in any gear including reverse, it will move, but has nothing when you give it gas. Like the pedal is completely dead. Shift back into nuetral or park and 90% of the time will rev up, but 10% of the time, dead pedal and does nothing. Please give me any ideas of where to start, thanks.
platinum01
Willis, TX
Sounds like your TPS (throttle position sensor) had a guy down the street with the same problem.
Somebody else may have some other ideas. They will be along shortly.
x2
the TPS is on the throttle pedal assembly
fairly common failure
roosterdiesel
Earl needs B100
Amarillo,TX
Check your fuses. I blew a fuse, don't remember which one, when I was installing gauges way back when.
Do you get all your normal lights on start up? If not you prolly have a blown fuse.
Brad1103
