Need to find a 3/8" brass Y with hose barbs
hheynow
Señor Aceite de Soja
Northern California
Not exactly a Y but I just found this from HERE. Now all I need to do is get them to ship me just one.
they had one like that at lowe's for 2.53, now it was in the plumbing isle alond with the PVC, ABS, CPVC, and all the other plumbing stuff, so not sure if it was thinner walled or what, but basically the same thing.
a TEE fitting is pretty common in all shapes and sizes, what are ya gonna do with it?
hheynow
Northern California
I relocated the heat exchanger in my SVO system so both tank's fuel now flow through it. This was done to give my B100 some heat to prevent any fuel filter clogging issues due to its high viscosity in cold weather. I noted a 162*F reading on my rear tank's fuel after the re-plumbing. The T (or Y) barb and a fuel selector valve is to create a manual bypass around the heat exchanger should I wish to run 100% #1 or #2 in my rear tank and wish to run it cold.
BTW, running on warm B100 ROCKS! :hail
