Need some help please
REDJAMESRACING
NC
hey everyone a newbie here first diesel truck ever
well i have a 03 superduty crew cab 2wd
i know diesel take a long time to warm up
my problem
my truck starts up just fine --- but pours out the white smoke
but it takes like 20 min to warm up
if i try to drive it before it warms up it runs like crap
like when driving down the road it start acting all erky jerky fealing look out the mirror and see white smoke when driving
so
i took it to a local dealer he ran the codes on there and nothing showed up
but the icp was leaking and he seen that the puter has never been flashed so he said that could be the problem the new diesel fuel they are using my be making my injectors run messed up so i said ok
get the truck back and it still runs the same
any help would be nice
thanks
RED
KRISTOLSON
Thief River Falls, MN
These trucks always have a little bit of a rough cold start/a little white smoke when it gets colder outside. If you feel it is really bad, I would take it back to the shop, have them keep it overnight, and run an injector buzz test when it is COLD. The buzz test is an advanced diagnostic function on their scan tool. The scanner will rapidly pulse (buzz) the injectors, all at once, and then one at a time to determine if one or more are malfunctioning. Lots of times you can have a sticky injector when cold that clears up when warm. It is common when experiencing really rough starts to have the injectors tested, have them all pass warm, and have 1, 2 or 3 fail when tested cold.
Another issue these trucks have is an exhaust back pressure valve. It will close when starting cold to help the truck warm up. If it sticks shut or is malfunctioning you could have an extended period of loss of power. It looks almost like a throttle butterly and is in the exhaust tube right after the turbo. It is possible to clean them or replace the actuator, but a lot of people just get rid of them. (search for ebpv delete)
snicklas
Super Moderator
Staff member
Greenfield, Indiana
I am not sure... but I dont believe the 6.0 has an EBPV since it has the variable turbp... i believe the EBPV is a 7.3 only item.......
KRISTOLSON
Maybe give them a call, I would suspect you have a sticky injector or 2 when your truck is cold. If you take it back and tell them it is not better, same problem, they might even wave the diagnostic charge to do the further testing. Do you have a warranty still?
ckamp52
ckamp52
italy,tx and stephenville
i would clean the egr valve and drain the water out of the collector by the fuel filter on the frame rail-sorry dont remember the correct name for it
