Question Need info on fuel tank breather upgrade
DOC-MX
FOREIGN MEMBER
Celaya, Gto, MX
I did the breather mod on the front tank using 1/2" hose and fittings.
I welded 2 nipples into the filler neck, (1 for the breather and 1 for the aux tank connection). It all worked great.
p.s. I purchased locking gas caps about 2 years ago and just now figured out they were unvented, so I drilled vents in 'em and what a difference that makes.
Glad to hear that all is working great.
What is the difference with the caps drilled you notice?
ward cleaver
Californication
The truck used to act like it was vapor locking/stumbling when I romped on it with the chip above stock setting, (no power).
Do a search for my post titled "Is it my TW Chip?" This went on for 2 years.:doh:
