I know this should go in towing section, but I'm stuck in the middle of the install, so I put it here so it would be seen quicker. (have mercy on me mods.)
Decided to put my B&W turnover hitch on tonight on my '04 Lariat CC short bed with FX4 package. Drilled the hole (measured carefully), removed heat shield, and put the cross members in between the bed and frame (had to notch the seam that hangs down). So far, so good.
OK, step 6 of the instructions (this is the 1108 kit, btw) says to locate the rear cross member about 4 inches behind the hole. I can't even get it within 8 inches of the hole because there's a hump in my frame that rises up and doesn't leave enough room under the bed for the cross member. The closest I can get the two cross members to each other is about 12 inches!? The center section is less than 8 inches wide. B&W is closed so no help there. Do I need to loosen the bed bolts so it will raise up or what??
