Apr 21, 2008 #1 Buffs F-350 Full Access Member Joined Jan 18, 2007 Messages 361 Reaction score 0 Location New Jersey U.S.A Im getting a CEL with a code p1335. 6.0 bible says "EGR position sensor minimum stop performance". What do you guys think time to replace the EGR or just a good cleaning?
Apr 21, 2008 #2 bushpilot Full Access Member Joined Aug 2, 2005 Messages 5,815 Reaction score 4 Location Tomball cleaning is cheaper... but if your gonna clean it make sure you replace the o-rings & base gasket
Apr 21, 2008 #3 Buffs F-350 Full Access Member Joined Jan 18, 2007 Messages 361 Reaction score 0 Location New Jersey U.S.A Thanks bush I knew you would answer quick. I will give it a try next weekend I have to find a dealer that has the o-rings.
Apr 21, 2008 #4 bushpilot Full Access Member Joined Aug 2, 2005 Messages 5,815 Reaction score 4 Location Tomball New o-rings and base gasket supplied in the o-ring kit, Ford part number 3C3Z-9P455-AB my dealer had it in STOCK cost all of about $7.50 FDDTS - 6.0 EGR Servicing FDDTS - 6.0L EGR Valve Cleaning Last edited: Apr 21, 2008
