Need help deciding
Fire1
Certified Diesel Driver
I am trying to pick out my father's day present. I am going to get some new speakers for the truck and have decided on Infinity components for the front doors. I am looking at the 6810cs and the updated 6820cs and the only difference I notice is the 6820 is 2 ohm. Would this be a problem with the factory deck running it right now? The Infinity site says that 2 ohm is preferable. What do you think?
Sleeper Diesel
Annapolis MD
for wiring it up to the factory. you should have 4ohms. if amped. 2ohms should be fine. the amp will get a little hotter than running 4ohms.
Fire1
Well it is a done deal. I got the new version that are listed as 2 ohm. The spec sheet actually show 2.65 ohm. So far they sound pretty good. Much better than factory. Those separate tweets sure add a lot. These ought to help drowned out the recently added Grover AIR HORNS.:D
Brad1103
