Need an Exhaust Gas Temp Gauge?
Cratos
Florida
yes I like it,
the edge will read all the egt sensors on the dpf 1-4 you can monitor up to 9 things at a time on it.
My truck is totally stock. I have an Auto Meter EGR that is independent of the computers. I want to see the real temps in the exhaust ports, not what the computer "thinks" the temps are. You are betting your engine in this gauge. I ran the same thing in my KW.
Cratos
Florida
you'll have to get a bung welded in the pipe that goes to the egr, to put you probe into.
You can thread the cast iron Exhaust Manifold to receive the temp probe. No welding needed. You want the probe to be as close to the exhaust valve as possible.
Dave :)
`08 Blue Crew
Somewhere in the lower 48
I admit that I do need to add one for monitoring egt while towing. as far as cool down, when I stop I shut down the motor, exit, lock the doors and use my remote start to restart the motor. It runs for 15 minutes then shuts down.
Jriltex
