Fordhorseplay
Rob
I have a 06 f-350, 6L diesel, and I am getting a tow haul light flashing and the tranny doesn't always down shift right at stops, it tries to take off in wrong gear then jerks into low gear, and when I'm going from park to reverse or drive, it hesitates shifting into gear. when i had the codes pulled it came out with a P1832 and P1876 codes. Ford said that the codes came from one of 3 items, the fuse (27), the relays or the electric motor on transfer case. I have since cleared the codes after replacing fuse and relays, but still got tow haul light again. I can change the electric motor but should this be affecting the way my tranny shifts and goes into gear? If not, can anyone give me other ideas?
thanks in advance,
Rob
thanks in advance,
Rob
