My turn I guess
The trucks been running just a hair rough lately and I hadnt been able to pin it down. The idle rpms were fluctuating by several hundred RPMs at 0 throttle, from a cruising position to no throttle it would want to drop down under 500 RPM and sound like it was laboring to idle...... she was just not happy. Well, on the way to work yesterday it finally set the CEL coming down off cruise to idle. When I got home I had the dreaded:eek: P0344 code. But from what I understand I am very lucky to have gotten that and not have been changing the CPS on the side of the road in the dark.:thanks
So, it was my turn I guess. Ive had her for nearly 3 years and over 60,000 miles now and this is the first time I had to change the CPS, not sure how long the other one was in there?:dunno
hheynow
Señor Aceite de Soja
Northern California
I'm counting my days too. Original CPS is 230K old.:eek: Glad my spare is in my glove box with the 10mm 6point socket.
Northeast Texas
yep real lucky
mine burped a few times at 75 ish.
like you shut off the key real quick
next day got me a new one.
bigfootpsd96
Norfolk,Va
my truck just cut off on me this morning slowing down to a stop light...but fried right back up whew....any ways who has the IH part number for the cps. i think i need to go get a spare. i have not the slightest clue if the one in the truck has ever been changed and she has 247 on the clock.
Camshaft Position Sensor (CPS)
(Ford) F6TZ-12K073-A 94-96
(Ford) F7TZ-12K073-A 97+
(International) 1821720C99 (below engine 375548)
(International) 1825899C93 (above engine 375548)
My CPS is 10 years old and has 60,000 miles on it. Still going :sweet I do have a spare in the truck and a spare in the shop just to be prepared.
slowgoin22
96 F350 CC LB 4x4
Seattle
Cheap CPS
I bought a cps froma guy I think crabmstr, on ebay. $62 shipped 2 day air. It's a ford factory part in the plastic and I would highly recommend him.
PSDfreak
Diesel-a-holic
Chico, CA & Newcastle, CA
I hear that loud and clear...150k miles on my motor and ORIGINAL CPS...I know it is going to dump out on me on I-5 @ midnight...that would be my luck :doh:
-Casey
clem
N.E.Ohio
Mine started going bad at 133k so I put on the spare on.Its easier to change at home than on the roadside.The truck would shut off at 60 mph for a split second.That happened 4 times in three weeks.I finaly got the hint.
