NORFLA444
I pull a 3 ton TT with a 750# tongue load, which pushes the truck all over the road; installed are torsion style equalizers and a friction sway hitch. When hooked up I can't keep the truck within my lane half the time and is pretty scarry. I've done nearly everything to correct it, including all new steering hard parts and ball joints, poly sway bar and trac bar bushings, bigger tires, Pro Comp single stabilizer and replaced a sticking caliper, but still tows like crap. So, the next step will be
- adjustable trac bar
- new box and pitman arm
- Rancho 9000XL's with My Ride controller
- Hellwig front and rear sway bars
- Pro Comp dual stabilizers
- Firestone R4 Tech or AIRBAGIT base tow kit
-285/65r18 Dueler AT Revos
Which begs the question: anything else to add to this equation?
