giodowd
I have a 2000 SD 7.3, my problem started about 2 months ago with a bad starter. I put a new starter in it and all was well for a few weeks then out of the blue it wouldn't start. Every now and then it will start fine, a few times I was able to get it goin by holding the accelerator to the floor while cranking. 90% of the time it will just crank and crank but won't start. I did a little T/S of my own and found the fuel pump was bad, I replaced the pump, filter and drain o-rings. I got my fuel pressure back but it didn't help my starting problem. I have a sneaking suspision it's either a leaking injector o-ring or bad actuation pump. Any advice or suggestions are much needed and greatly appreciated.
