My diesel will not crank
Jimbojames
OK I am new here I have a 2000 Ford Excursion. When I turn the key nothing happens. I installed a new seloniod. I also installed a new alternator not to long ago. I have checked the relays under the hood. I can jump the truck at the seloniod. Is there any fuses that power the truck? I checked the 2 the onwer's manual stated about ignition and they seem fine. My last thing to think of is the neutral safety switch. Any help would be great I really need to get this running right again.
oi8228oi
another 99
OB NJ, land of traffic, stop lights, stop signs, a
Tbar
SDD STAFF/Moderator
If you can jump the truck off at the solenoid it would suggest either a bad solenoid or no voltage current to the solenoid. Have you checked voltage at the small wire when you turn the key to the start position?
Tbar
Jimbojames
I did check it and it is not getting any voltage to the wire. I really need some help.
whatabudro
Launched
You need to check the DTR (digital transmission range sensor) Which is like a nuetral safety switch.
Can't tell you where its is but that is what my manual says to check.
