mounting compressor & horn on 2002
jmanf250
San Pedro, Ca
Help Please
i have a cmprsr with a pressure switch ...on wire from the cmprsr to the PS then the other from tehe cmprsr to Grnd... then the other open end of the PS gets the HOT lead from the upfitter switch. THIS ALL WORKS GREAT! Compressor comes on perfectly when i turn AUX4 Upfitter switcher on....... now issue is ... i have an electronic solenoid for the horn.... i have a seperate horn button as well. STOCK HORN IS NOT effected in this set up. SO...one wire from the horn switch goes to ground and one to the ??????
and
Solenoid wires go where??? there are 2
please someone help???
thanks
Iknow im a dork not to be able to figure this out.... sorry... i build houses not wire them
:dunno
JJKpowerstroke
Southern New Jersey
Hello, the soleniod will activate when you push the horn button. One side of soleniod goes to ground the other is the hot side 12v. Make sure it is grounded to a good ground. And Make sure Compressor is fused correctly. A pressure control dictates when the compressor cuts-in and cuts-out.. So fused power lead from battery to one side of presssure control then out of pressure control to hot side of compressor.
Hope that helps, John
Jriltex
