Ford_Forgotton
Just FYI, it appears the MOBIL-1 has changed their Synthetic ATF.
It is now DUAL RATED, Mercon-V compatible.
By the Ford manual, it is NO LONGER compatible with our 4R100 transmissions.
You may still be able to find the original bottles that are just MERCON rated, but read the label carefully and make sure there is NO MERCON-V rating on it anywhere.
If you have an aftermarket rebuilt tranny such as a BTS, you should go by the recommendation of the tranny builder, as your transmission may no longer have the ford parts that required the MERCON only fluid.
