Military Hummer tires & wheels $50.00
arrowstrap
BioMechanic
wa
i had a feeling you would be the one to post a reply Big K. I'm trying to size up a set of tires. at what size tire do i have to change my gears? i think i'm rolling with stock gears.
arrowstrap
BioMechanic
wa
uhm, what? i've no idea. thats why i'm asking. transfer case gear ratio right? i dont wanna go and throw a set of tire on it and then blow my tranny cause i didnt ask about it first.
most of my driving is highway.
Big K
SDD.com Hacker/Admin
Dallas, Texas
There should be a Tag on the rear axle with some numbers.
If you get those numbers I can decode them, should tell you the gears in your axle, the front would have the same gears if it is stock ;)
Big K
Dallas, Texas
The Tag might look like this:
S132C
4L10 102 4C26
Lets break down the numbers:
S132C:
* S = Sterling Differential
* 132 = Print Number (Model Number)
* C = Revision Identifier (Change in Design)
4L10:
* 4 10 = 4.10 Gear Ratio
* L = Limited Slip
* Absence of L = Open Differential.
* A 3.55 geared limited slip axle would be marked as such 3L55. An open differential would show 3 55 or 4 10.
102 denotes the ring gear size. 10.25 inches.
4C26 is the build date.
* 4 = year of manufacture. In this case it means 1994.
* C = month of manufacture. A= January, L= December so C= March
* 26 = day of manufacture. So My differential was manufactured on March 26, 1994
(Found this stored in a file, was looking for it :) )
94redbeauty
Pullman, WA
I dont know if its the same on the D60's but on my rig with the 50 I have a yellow sticker on the backside of the axle upside down that says "D50" and gives the gearing "4:10" and says a few other things
Skram
