Mileage on other 7.3's??
Sleeper Diesel
Annapolis MD
an average of 16 with about 500lbs in the bed. i have a similar chip. intake and exhaust helps all around on these trucks. you should have some gauges if you dont already.
dugweed
Loose nut, Ford nut
Illinois
I get 14-16 depending on how my leadfoot syndrome is doin,
Mike
blueballin
Enid,Oklahoma
you need to do two things... add lubricity to your fuel... run B20 or see this thread poke here
and add a cetane booster
Thank you very much for the info! I read the link to the previous posts and have a couple questions. Do you run both the cetane booster and the TCW3 outboard oil together or at different times. Also a super newb diesel question! How can i tell what type of diesel fuel i am buying. Example: B5, B20 and so on. Also, is all diesel fuel that is sold today from a basic gas station ULSD? Thanks!
bartman
Dallas, TX
I get 12. All I ever got was 12. Stock was 12 and now mod'ed is 12. I use Stanadyne with every fill-up. B20 got me 12. I've kept a chart of the last 18 months, and it has all sorts of driving in it. I wish I knew why I can't get better.
Frankenstien
Frankestien
South Prairie Wa.
May want to try a different Calculator.... :roflmao
bartman
Dallas, TX
I wish...lol... :( but it's a simple miles driven/gallons used calculation. I think there was a mileage thread posted a while back where I shared the file. If I think to do it, I'll look it up.
yes, run the TCW3 and the cetane booster at the same time IF you are using ULSD... if you have access to bio (which has to be labelled as such on the pump), use it and a cetane booster... no need for the lubricity of the chainsaw oil..
Brad1103
