methanol?
black_cloud_stroker00
GO BIG RED!!!
Bellevue, NE
where did you mount the nozzles? can you mount them in the passenger side intercooler pipe? I Did the AIH delete mod, is it possible to fab that plug for a nozzle?
GO BIG RED!!!
Bellevue, NE
whats your max psi at the max setting? my truck is borderline between stage 1 and 2. I can build more than 25psi in the top chip setting, but I am under 350hp.
whats your HP/TQ, what gains did you get from the methanol? Snows claims 70hp.
what psi levels is the controller set at?
where do you get your boost juice?
sorry about all the Q's, I just want to make sure i get the right thing.
GO BIG RED!!!
Bellevue, NE
my engine compartment is kind of cramped. I don't think I have any room for the reservoir. Other than a remote location (in the truck or in the toolbox), I have been tossing around the idea of using the windshield washer fluid res. except filling it with 50/50 meth and water. I realize that I would not get as clean of windshied, but i don't really use my squirters that much.
we did you guys mount your reservoir?
CSIPSD
Bend, OR
Mine is mounted in the tool box, 8 gal res... only way to fly... The WWF res will be empty in less then 40-50 miles of driving.
First stage comes on at 8 psi full on at 15 psi. I get 40hp on the dyno at 40% meth... Snows is smoking crack saying you will get 70 hp...
GO BIG RED!!!
Bellevue, NE
i imagine that the 70hp is at the flywheel. You also have really big tires.
My truck is a daily driver, so I guess i'll only go with the 2 qt. I don't really plan on have the meth on all the time. Just when i want to be a hothead. The 8 gal is too expensive, and i don't know where to mount the 7 qt.
Do you know the size of the WWF reservoir?
I ordered the Snows stage 1 kit and it should be here this week. who knows when it will get installed, because dove season starts Sat.
