Marry Christmas to me!!!:(
Dogman
tampa,FL
Have you pulled the boost tubes and checked them for oil, also check the fresh air tube up at the turbo. If you have oil in the fresh air tube your most likely having a crank case venting problem. If that dry and oil is in the boost tubes then theres a good chance you may have a seal going out in the turbo.
Get Pumped
Spring Hill, FL
Thanks!!, ok so I havent checked it yet.. Is there a turbo rebuild kit for the 05 6.0?
Im a pic guy... Is there anyone that has pics of the boost tubes? So I know what Im looking for..
Ill be pulling the air intake side tomorrow to see what's in there..
Thanks for all the info to check.. Lance
