i cant see it being a mechanical problem if your not blowing white smoke out the tail pipe but it could be the wiring to your injectors. i had a low boost miss at one point but it turned out to be the wrong programmer as the cause to my problem. another question is how many miles are you sitting at?? i know around 230,000 is when the wires usually start being a problem.
