Low Boost, Got Codes
roosterdiesel
Earl needs B100
Amarillo,TX
THe 21-22 psi could be what the WG is set at. Unplug it and see if it goes higher. I don't recomend running it disconnected all the time. How oily are your boots?
The EBP codes are probly either a bad sensor, clogged tube or the stock exhaust is too restrictive. Use the data streams under the diagnostics part of the Evo and report back what your back pressures are at WOT.
Got Diesel
Engineering College Boy
Missouri
The Boots on the drivers side are oily for sure. What does that mean? Ok tomorrow I will get the pressure at wot.
Got Diesel
Missouri
I got the Exhaust Back Pressure. It never goes above 53psi. Doesnt' go any lower either. Is this normal?
Got Diesel
Missouri
Ya even at Idle, it may drop to 52.9 but that is it. What would that sensor cause? Could it be the tube?
roosterdiesel
Earl needs B100
Amarillo,TX
The EBP codes will cause a defuel I believe. I don't really know what a clogged tube would make it read.:dunno: Pull the sensor to check if the tube is plugged. I think it's a 1" deep socket or wrench.
dpantazis
#12
under the cheddar curtain
the tube can get plugged up with rust or soot not letting the sensor read correctly.
or the sensor will go bad.
either way, the sensor value will trick the PCM to defuel.
removing the sensor will let you see if the tube is plugged.
you can unplug the sensor or the EBPV solenoid wires and see if the power & boost are back.
I have read in many posts where people could not separate the EBPS from the EBP tube.
